16. Juni 200521 j hallo! beim starten des apache 2mit ssl bekomme ich die meldung www4:/etc/apache2/vhosts.d # rcapache2 restart Syntax OK Shutting down httpd2 (waiting for all children to terminate) done Starting httpd2 (prefork) Apache/2.0.53 mod_ssl/2.0.53 (Pass Phrase Dialog) Some of your private key files are encrypted for security reasons. In order to read them you have to provide us with the pass phrases. Server www4.~~~~~.de:443 (RSA) Enter pass phrase: An SSL passphrase has not been entered within 2 seconds. To increase this timeout, adjust APACHE_START_TIMEOUT in /etc/sysconfig/apache2 . Trying to start the server without SSL (-D NOSSL). Apache:mod_ssl:Error: Private key not found. **Stopped Starting httpd2 (prefork) Apache/2.0.53 mod_ssl/2.0.53 (Pass Phrase Dialog) Some of your private key files are encrypted for security reasons. In order to read them you have to provide us with the pass phrases. Server www4.~~~~~.de:443 (RSA) Enter pass phrase: An SSL passphrase has not been entered within 2 seconds. To increase this timeout, adjust APACHE_START_TIMEOUT in /etc/sysconfig/apache2 . Apache:mod_ssl:Error: Private key not found. **Stopped Trying to start the server without SSL (-D NOSSL). Starting httpd2 (prefork) Apache/2.0.53 mod_ssl/2.0.53 (Pass Phrase Dialog) Some of your private key files are encrypted for security reasons. In order to read them you have to provide us with the pass phrases. Server www4.~~~~~.de:443 (RSA) Enter pass phrase: An SSL passphrase has not been entered within 2 seconds. To increase this timeout, adjust APACHE_START_TIMEOUT in /etc/sysconfig/apache2 . Apache:mod_ssl:Error: Private key not found. **Stopped Trying to start the server without SSL (-D NOSSL). Starting httpd2 (prefork) Apache/2.0.53 mod_ssl/2.0.53 (Pass Phrase Dialog) Some of your private key files are encrypted for security reasons. In order to read them you have to provide us with the pass phrases. Server www4.~~~~~.de:443 (RSA) Enter pass phrase: An SSL passphrase has not been entered within 2 seconds. To increase this timeout, adjust APACHE_START_TIMEOUT in /etc/sysconfig/apache2 . Apache:mod_ssl:Error: Private key not found. **Stopped Trying to start the server without SSL (-D NOSSL). Starting httpd2 (prefork) Apache/2.0.53 mod_ssl/2.0.53 (Pass Phrase Dialog) Some of your private key files are encrypted for security reasons. In order to read them you have to provide us with the pass phrases. Server www4.~~~~~.de:443 (RSA) Enter pass phrase: Apache:mod_ssl:Error: Private key not found. **Stopped server.key & server.crt sind vorhanden ! muss ich den private key irgendwie vorher entschlüsseln? woran kann es sonst liegen? mfg
16. Juni 200521 j so... problem gelößt!! war kein fehler drinne nur beim neustarten wurde immer nach dem pass phrase für den private key gefragt! dieser is aber leider unmöglich da einzugeben da das scrip "zu schnell" läuft... naja musste zertifikat entschlüsseln und dann noch einmal den Passphrase eingebn. Jetzt kann der Key geladen werden, ohne das eine Passphrase abgefragt wird. Um den Key zu entschlüsseln und die Passphrase zu entfernen ist der folgende Aufruf notwendig: openssl rsa -in server-rsa-key.pem > server-key.pem wens interessiert ..
24. September 200521 j I have the same problem! Redhat Fedora 4. You can answer in German if you like... TNX, Etienne so... problem gelößt!! war kein fehler drinne nur beim neustarten wurde immer nach dem pass phrase für den private key gefragt! dieser is aber leider unmöglich da einzugeben da das scrip "zu schnell" läuft... naja musste zertifikat entschlüsseln und dann noch einmal den Passphrase eingebn. Jetzt kann der Key geladen werden, ohne das eine Passphrase abgefragt wird. Um den Key zu entschlüsseln und die Passphrase zu entfernen ist der folgende Aufruf notwendig: openssl rsa -in server-rsa-key.pem > server-key.pem wens interessiert ..
